Try This Stuff
Propylene oxide is a highly toxic flammable chemical compound. It is an epoxide having a molecular formula C3H6O. Other names include methyloxirane and 1,2-epoxypropane. Propylene oxide has a single chiral center, and thus has two enantiomers. The material commonly available is a racemic mixture of the two enantiomers.
Propylene Oxide. This fuel additive in general is safe to handle except for two possible conditions, which under certain cir***stances could well be dangerous these are the effects cause by the fuel coming in contact with copper/alloy containers, fuel tanks, etc., or by rust particles getting in the fuel by accident, for example from a rusty container, or from rust from damaged can top cap.
The best increase in power is obtained by some 5 percent as additive, as above this figure the gain does not increase in proportion, like the other additives, but in fact tends to decline, so stay at the 5 percent mark.
