Hello, I was wondering if anyone knew the exact oil mixture ratio Yamato suggests in the manual? My drive shaft housing keeps filling with unburnt oil. I can only assume it is pooling up in the crank case and finding it's way through the lower seal and filling the driveshaft housing as a result of being too rich. Thanks for any help anyone can spare.
Oil...????
Why are you guys running so much oil? Why not run synthetic and use less oil? Just asking....
MikeSattler Racing R-15
350cc Pro Alcohol Hydro
TEAM VRP
The Original "Lunatic Fringe"
Spokane Appraiser
Originally posted by bill boyes View PostI run Red Line at 20 to 1.
I know everyone has their own way of doing things, just thought I would throw this out for everyone if anyone is interested.
TEAM VRP
Spokane Appraiser
Originally posted by jsilvestri View PostI've been running synthetic oil in all of my race engines for about seven years now, which includes merc's and Yamatos and I run 4oz. to the gallon. This is exactly what the manufactorer recommends. I've never had a problem with lubrication.
Yep, thats 32 to 1Sattler Racing R-15
TEAM VRP
Spokane Appraiser
Originally posted by proprider View PostNo excessive oil in the crankcase, mostly dry in the exhaust pipe and no fouled plugs.
TEAM VRP
Spokane Appraiser
Originally posted by pro350hydro View PostWhy are you guys running so much oil? Why not run synthetic and use less oil? Just asking....
Mike
I do run synthetic and less oil now.... Instead of 3 pints to 4 gallons I'm running 3 pints to 5 gallons.Last edited by David_L6; 08-08-2007, 09:22 AM....
Originally posted by proprider View PostI have run synthetic at 32:1 for about 12 years and have had no issues. No excessive oil in the crankcase, mostly dry in the exhaust pipe and no fouled plugs. Good luckI figure if I get enough oil in the crankcase it can't all leak out as quickly as it's going in so it seals up all the leaks.
