Thanks for the words of encouragement Dean. It doesn’t need to be perfect, just has to look good from the beach!
Minor project CSH
Originally posted by baries View PostYou're describing a 50/50 paint job. Fifty feet or 50 mph.
Also I should note that while the boat is a little heavy and the paint wasn't to my taste it does seem it was well cared for and looked after by the previous owners, and whoever built it seemed to do a nice job. It should make for a good solid hopefully stable boat to send out new drivers in and help test my extra motor on.
Full disclosure, I don’t know anything about wood working. I know even less about what makes a fast boat but the leading edge of the front deck was almost square so I took 20 minutes today and rounded it off to a smooth finish. Maybe that’s only a cosmetic modification but I’m happy about it.
Also got most of the right hand coaming sanded, almost ready to put the 80 grit away and work with something a little less aggressive.
Letting momentum carry the project into the unknown.
I could tell I burned through the epoxy into the wood on several places and wanted to make sure it was sealed so I got some spraymax 2k epoxy primer and hit all those spots with a couple coats after sanding with 180grit. Will follow up with a couple coats of regular primer over the boat before sanding again then base coat.
- 2 likes
Two things learned today, spray can filler primer sucks.
Secondly the plexiglass front cowl is not being re-installed. The boat is going under the knife. Featherfil primer filler is on order for Monday.
95912F32-F4F1-4788-946D-7C1C8B565336.jpegLast edited by Albert; 01-28-2023, 05:58 AM.
What surgery are you doing? Are you going to do a wood cowl?"Keep Move'n" life is catching up!
A new cowl was made today but I can’t for the life of me get pictures to load.
- 1 like
It’s been released on good behaviour.
- 1 like
