Nice work Mike! Can't wait to see them in person. See ya in a few weeks..
Montana RaceCraft 2012 projects
I'm not sure how much I'll run D-Mad this year, but we just did finish up the motor (a 3 year, slowly moving project). We are making 4 four blades, four different shapes to see how the boat handles the extra power.
But once we get all of the boats to the west side, D-Mad takes a back seat to these CSH's. We've go at lot of dialing in to do in a fairly short amount of time...
It's really fun having Jimi in the shop with me making the Oberto/Wayneco props. He loves data and repitching props, which lets me grind away. Sorry we can't show you pics of the half dozen that are all finished. Can't wait for testing of the new boats and props as the wind did not let us test this weekend. Working on a stack of new Dmod 4 blades now. They will work for Guedo or Daren and I'm sure they will be fast!
Originally posted by guedo499 View PostI'm not sure how much I'll run D-Mad this year, but we just did finish up the motor (a 3 year, slowly moving project). We are making 4 four blades, four different shapes to see how the boat handles the extra power.
But once we get all of the boats to the west side, D-Mad takes a back seat to these CSH's. We've go at lot of dialing in to do in a fairly short amount of time...We are having a big test session the last weekend of April!!
stain
Originally posted by blueskyracer View PostDeck wood has now been stained and working on the kill switch install under the deck"Keep Move'n" life is catching up!
Originally posted by ZUL8TR View PostWhat is brand and color for the stain and I presume it is water based?
I did this to our boat the "Bucket List" 5 years ago and it still looks like new.. It is my favorite stain and color so all the funiture I built for our house is the same color.Mike - One of the Montana Boys
stain
Originally posted by blueskyracer View PostIt was developed to stain exterior fiberglass doors and is called gel stain by Minwax and it is I believe Mohogony 509.. I probably have it spelled wrong but anyway after it dries completely I will install it and then a coat of epoxy, wet sand, and then coats of varnish with wet sand between coats..
http://www.minwax.com/wood-products/...nwax-gel-stain
It is an oil based product. I read on this site or BRF that oil based stains are not to be used under epoxy only water based stains. Your success with it kills that theory."Keep Move'n" life is catching up!
It is an oil based product. I read on this site or BRF that oil based stains are not to be used under epoxy only water based stains. Your success with it kills that theory.Mike - One of the Montana Boys
Stains
I am surprised that one works. I did a lot of test piece several years back with about all of the stains from the lowes type stores, including minwax.
Here is what an inboard restoration fella told me.
You can use Oil based stains and cover with West System. The trick is to let the stain dty completely and then sit for a month or two to let the Oil evaporate, then it is good to go.
In my test pieces I did, I found a couple oil stains that West did not like, and the strength was gone. It still covered, but the tensil strength was not there. So if you are using West as a coating, with Oil based stains, it will cover, you just won't reap any strength rewards. And I did find a couple that it flat did not work with. Best to do a test sample before doing the whole boat. Looks like Mike found a combo that works. Looks nice too.Dave Mason
Did research on stain compatibility when I refinished my old Sorensen... one company has a pretty extensive database on West System epoxy adhesion to various stains, URL is http://www.epoxyworks.com/21/index21.html (then click"Epoxy adhesion over stains" link on left).
Based on data on above site, I ended up using the Minwax waterbased stain - worked great... They gave Minwax Gel passing grades too so Mike safe there.
