Per the new 2010 Stock Outboard Rule Book that is on APBA's website the 2010 Class/Engine Structure is listed as follows:
ASH/ASR - OMC "A", Mercury "A", Sidewinder 15S (Probationary)
BSH - Yamato 80, Yamato 302 with 7/16" restrictor, Sidewinder 20S (Probationary)
BSR - Mercury 25ss, 25XS (no restrictor), Hot Rod 20ci, Yamato 80, Yamato 302 with 9/16 or 1/2" restrictor, Yamato 102 9/16 or 1/2 restrictor, Sidewinder 20S (Probationary)
CSH/CSR - Yamato 102 & 302
DSH/DSR - Mercury Mark 55H, 402XS, Mercury /Mariner 44XS, Bass Tohatsu
15SSH/15SSR - Hot ROd 15ci, Sidewinder 15H
25SSH - Mercury 25ss, Mercury / Mariner 25xs without restrictor, Hot Rod 20ci
45SST - OMC 45ss
So watching and participating in the threads this fall is it correct to assume that the SORC will be asked to;
1. Approve the Sidewinder 15S in ASH/ASR
2. Approve the Sidewinder 20S in BSH/BSR
3. Leave the Mercury "A" as a legal motor in ASH/ASR
Other:
4. What other motor changes are up for consideration if any?
5. Personally I think that both Hydro and Runabout classes with the same letter classification should have the same motors listed as legal, ie BSH / BSR then add 25SSR back in to the class structure. It sure would make it less confusing...
If these changes go into effect can we ask the SORC to put a 5 year freeze on motor deletions from any class so we can just go race?
45SST - OMC 45ss
Other:
