The owners manual I got from Ric Montoya says the Y102 timing can be set from .200 to .250. Bob G. said to set the timing after replacing the #2 cylinder points (he advises to replace and set the adjustment on the #1 cyclinder points first). I usually set the timing as close to .250 BTDC as I can get it, but have used .235 also. I have two standard-bore, Y102 motors with R8102A-10 NGK plugs (one mod, one "stock").
Any thoughts out there on alternate settings for the Yamato 102 timing?
Al
Al
