Make sure you are using a fitting that is the same length (reach as the plug you are using..
For instance 25SSH motor use a long reach plug, I built a motor for a guy and he checked the compression with his tester and a short reach adaptor and got like 90 and 100. I used my Mac Tools tester with a long reach adaptor and got 140 per hole.
Thanks for all the great advise guy's. I just got home from work and checked it again. I kept roping it until it quit gaining pressure. It read 140-142 psi. Phew, that's a relieve to know the rings and cylinders are in good shape after last weekends tear down and reassemble. Yes it got thirsty for some of that muddy water at Burlington
Mark G-11 125H When the green flag drops, the bull**** stops!!!!!!!!!!! Keep'em Sunny Side Up Boy's!
