On the Y80 have any experienced the point cam cracking starting at the top where the key slot is ? The cam key slot was machined at the thinnest part of the cam so not much meat there, suppose that was a design flaw since the Yamato 102 moved the slot to the thicker part of the cam?
Y80 ignition points cam issue
Originally posted by Jack Stotts View PostI've broken many a cam on both the Y-80 and 102. Tom Johnston (TJ) has them or at least had some.I got a 102 cam last year from him but don't have any idea about them for the Y-80. Jack
Any thoughts on why they crack at the key ? Where were your 102 cams cracking? Am I correct the 102 has the key slot in the thick part of the cam I know the Y80 does not and that's why I thought it was a design flaw with the key way in the thin area of the cam?"Keep Move'n" life is catching up!
Yes, they crack at the key slot. There are cams out there that have two key slots, one for y-80 and the other for the Y-102. They crack at the key way as you have noted that that is the weakest place. The Y-80 broken cams that I have broke at the key slot. The ones that have two slots are also cracked at the y-80 slot (the weak area).
Originally posted by Jack Stotts View PostYes, they crack at the key slot. There are cams out there that have two key slots, one for y-80 and the other for the Y-102. They crack at the key way as you have noted that that is the weakest place. The Y-80 broken cams that I have broke at the key slot. The ones that have two slots are also cracked at the y-80 slot (the weak area)."Keep Move'n" life is catching up!
Yea, the 80's are a bad design. That is why the 102 has the key way in the fat part of the cam. I found that many that cracked was because the key itself was exerting pressure on the cam. Solution one, make sure the key is flat. Solution two, rub the key on a stone and round the edges some, no sharp point.
