I'm getting ready to put an OMC gear case back together, what should I seal it with?
OMC gear case question
OMC gear case
The clearances inside the OMC gear case are quite close; I have found that any number of the Loctite anaerobic thread lockers work well. Most recently I used Permatex Threadlocker Blue Gel with good results.
My experience with Loctite 518 Gasket Eliminator (for aluminum flanges) has been less than satisfactory; it is quite viscous and started to cure so quickly that I felt that I didn't get the halves fully tightened together before curing started.
Don't forget to secure the water pump impeller first.
The Loctite stuff has worked good for me. Here are a few part numbers which all end up being the same material:
Yamaha Gasket Maker, by Loctite: 90790-74001-00
Gel Seal Sealant, Evinrude-Johnson (OMC) Bombardier: 327361
Loctite 518 Gasket Eliminator/Gasket Maker (flange sealant): 51831
The Sierra # for the above is: 37394
All of these recommend that the surface to be sealed be completely clean and "primed" with Loctite 7649 (part #21348) or Loctite 7471 (part #22477) or Loctite Klean N Prime: OMC#384884
The Sierra # for the above primer is: 37509
One of the keys is to make sure all the sealant is removed from the surface. It is virtually invisible and you'd think it wasn't there until you spray some gasket remover or paint stripper on there to loosen it up. Laquer thinner, carb cleaners, don't always do the trick (I have found). And the old sealer, thin as it might be, still keeps the case halves from clamping tight around the internals.
Just my 3.5 cents.
Alex
Loctite 515 is an anaerobic cure, while 518 is room temperature cure. I wouldn't want any hard cured sealer inside my lower unit, I strongly recomend the Loctite 515.
http://www.loctite.sg/sea/content_data/93791_515EN.pdf
http://tds.loctite.com/tds5/docs/518-EN.pdf
I've done okay with the stuff I mentioned above (and I assume it is all really just 518). That was an expensive experiment I might add.
I'm careful not to load the surface with too much and try to get the case together quickly and torque it. There isn't much surface width on those omc A cases and trying to keep things free of grease (like around the impeller area) is a PITA. Gotta luv it.
Joe's gearcase
Here is the deal with Joe's gear case....
At speed you could hear a low pitched hum as he went by the pits. Inspection of the gear case showed badly worn teeth where the pinion shaft engages the coupler. All new parts were put in but now you can hear a high pitched scream as he passes the pits.
After taking the case apart I measured the shims on the pinion shaft at .036 (not including the thick one with the tab which measures .060) Total thickness is .096. I was told the case sounded to tight.
Is there a "baseline" measurement of shims that will get us in the ballpark? What is a good starting point?
Thanks for your time,
Russ_____________________________________________
Russ Waterson
sigpicSIBLING RIVALRY RACING TEAM
This works as well
Get it at any NAPA store.Part number on lower right of tube. Same as the OMC gel seal. It only cures AFTER the parts are put together and will not dry when left open to air,even overnight.
Anaerobic is a technical word which literally means without air. Thus meaning it cures witout the presence of air.
Good luck !!Tom L.
Gear case noises
The shims under the pinion gear and in front of the propeller shaft gear are used to compensate for gear case tolerances; installing a new pinion or prop shaft gear should not alter the shim pack much, if at all. (Assuming the original shim selection was correct). Ideally the initial set up of the shims should be made without the pump installed, so you can 'feel' how the gears are meshing. The pinion should have some vertical movement, and should be pulled away from the prop shaft when checking back lash and 'feel'. When turning the shafts by hand it should feel smooth with only a hint of gear meshing. If properly maintained these gear cases will last almost forever, except for the impeller.
