I am soon to be rigging my new B&H csh and have an old Keller 188 steering hub with a small 3" dia cast cable drum.If I use this system and connect the steering cables directly to the steering bar will the ratio be close to a much larger drum with indirect steering through the steering bar and to the tie backs ? The indirect cable routing seems to be the most popular method.Is the "steering effort" much lighter with the lower ratio ie; large cable drum and tie back's? Thank's for the advice.............36cw
