Mercury 1965 200 Conversion?
  • Mercury 1965 200 Conversion?
    Has there been anything made to convert this motor over to a racing version for cottage racing? Thanks!
    John
    That powerhead should bolt-up to the Q/H "Quickie" towers/gearfoot.....search "racing" on e-bay motors in "boating"...click on this and enter in favorites....one will show up http://motors.search.ebay.com/search...e=search&fgtp=
    19P
      here's a "H" tower housing (will prob go $300-400)
      http://cgi.ebay.com/ebaymotors/MERCU...QQcmdZViewItem
      Exspect to pay $650-$1200 for gearfoot that goes with it....
      19P
        Thanks Steve for all your help! Used to run Kg-4's, Kg-7's and Mark20H's back in the 70's. Not quite ready to jump yet but I really appreciate your help. Are there any other parts I'll need to convert. Will the current main drive shaft from the power head work or will I have to use a shorter racing version. Are the splines the same at the top? Thanks again!
        John
          John
          If yer powerhead has a water inlet like the Mark-28 (early 200) and the kg-4/7/Mark 20-25....it should bolt up and the Q/H driveshaft/spline will work....If a newer powerhead and the lower water passage is more of a troth (spell check!), you may need to use a adapter plate like the 25SS to run water. Then a 25ss length shaft or a coupler/two piece drive shaft (made from your drive shaft/any early 2-cyl fish'n foot shaft) will be needed. I have found the 9/16" deep, snap-on sockets ID fits the 9/16" Merc shaft OD well, when cut to length, and welded to match/drive a short 3/8" squared "stub" drive shaft aprox 3" length from top of gearfoot...Also see if you can measure the width between the two rear studs...on new'r powerheads, this dimension is wider and you can git away without those two studs but a 25ss tower would then be prefered to use all the studs.......This is how I run my early Mark-28 25MOD/A-MOD......Will post some pics when we git back home from visit'n family next week.......Have you pulled motor down to were you can see bottom of powerhead?
          19P
            PS....If yer 200 is a good complete work'n fish'n motor,....take a look around for a donor motor preferably a Mark25/28....these match the bolt pattern/water tube on the tower without any adapters.......your 20hp/200 if complete, still has alot of value as a fish'n motor......unless this is the powerhead ya WANT to use.
            Here's a couple links to put in yer "favorites" and watch http://motors.search.ebay.com/search...trypage=search
            19P
            Here's one ...save yours and build from this? http://cgi.ebay.com/ebaymotors/1960-...QQcmdZViewItem
            You might also find some info in this thread http://www.hydroracer.net/forums/showthread.php?t=7251
              Thanks Steve for all your help! I'll keep my eyes open
              John
                Merc 250
                The Mercury 250 was a single model year engine built in 1962. From the outside it looked very much like the 200's with the same lowerunit that was a bit hard to work on. I have never set it along side one of my 25ss engines or compared the innards. I would assume the engines had the same basic power as the current 22 cubic inch engines. I will do a parts manual check and see if we can find some commanality.
                Ala
