I'm becoming a total water-head?
Hi there world of hydros! I am brand new at this great sport and am starting off on the Minimax level. I am wondering if anybody knows about how far my prop should be in the water when the boat is compleat? I am building the motorboard now and my brain is turning to mush over how tall, or short the thing should be. The motor will be a greentop KG7 H. Any info would be apreciated. (this is my first post here as well, Woo Hooo!) Thanks.
Tags: None
Originally posted by Aqua Zombie View PostHi there world of hydros! I am brand new at this great sport and am starting off on the Minimax level. I am wondering if anybody knows about how far my prop should be in the water when the boat is compleat? I am building the motorboard now and my brain is turning to mush over how tall, or short the thing should be. The motor will be a greentop KG7 H. Any info would be apreciated. (this is my first post here as well, Woo Hooo!) Thanks.
That's OK
Originally posted by Aqua Zombie View PostThank you Dean. That lines up with every thing I have heard. I wonder though... Am I over engineering it to make it an inch or so lower, leaving me the option to shim it up for more adjustability?
Good Luck.sigpic
Hey AZ, check out www.muskokaseaflea.ca, dedicated minimax/most fanatics, largely in Ontario, Canada.
I have a KG4H, goes like stink. Your boat will fly!Stock Outboard Racing!....because other sports,....golf, football, baseball, etc....only require one Ball!
Yes, your over-engineering it.
You would never run this with the cavitation plate below the bottom. Ever.
Back in the day, some people were known to run that with the center of the prop shaft level with the bottom. I dont recommend that.
So thats your high and low max dimensions.
Set it up with cav plate level with bottom to start. raise it up 1/4" at a time till the prop looses bite. Go down a quarter, your good.
Good luck with your project.
BW302SSH.....Putting the Stock back in Stock Outboard
Thanks all again! It is starting to make a little sense up in my wheelhouse now! Though the gears do turn a bit slow up there. Ill get some pics up for you all as soon as I figure out how. And to you B Walker... that is what had my head spinning a bit, because I have heard of people running their prop halfway in the water before. I am new to all this and learning bit by bit every day. This project is just the start. I can feel it getting into my viens allready!
all racing applications run the CENTER of the prop pretty much at or just below the bottom of the boat. Even though it may seem counter intuitive (didnt make any sense to me a couple years ago) running the prop half out of the water is faster.. by a lot. Thats why, in a lot of classes, there are restrictions to exactly how high you can run the motor. At a certain point it can become dangerous and/or cause damage to the motor, such as being hard to control and starving the motor of water causing overheating.Last edited by Silas_53A; 04-05-2010, 07:10 PM.Silas Jordan
Windham, Maine
Sigma Nu, IN-549
