What is the best/safest way to set-up the steering cable once it is run through the indirect steering tie-backs? Do I need to secure the excess cable?
Indirect Steering Set-up
Yes
I recommend two cable clamps on each side. If you look at the hardware suppliers on this site, Tom Cronk, Machined Components, and others they offer these. They work great, and at least one is required, in some categores and organizations two are required on each side.Dave Mason
I'd evaluate what the maximum length you would ever use and cut off the excess. Use the deadman as the primary clamp and then one additional clamp on each side. APBA requires a double clamp. I'd minimize any excess cable but if you have some, I'd tape it in place. Just one more thing to catch on as you exit the boat either intentionally or unintentionally. JackLast edited by Jack Stotts; 04-23-2013, 09:06 AM.
