Ok Cut them to fit or you be sorry. Trust me on this.
302 compression ?? External fuel tank??
Will do. I'd rather not burn up a piston. But thats not the only reason i would think you would have to cut them off.
If they were sticking out would that not affect the cc's?
Possibly a very small ammount. but for those who are already at the min it might?Last edited by me-otch; 11-05-2010, 07:58 PM.Mitch Knapton 44-CE
CMH
Originally posted by guedo499 View PostThe only thing I would worry about is that the two cylinders are not reading similar compression. The OSY motor that I run has much less than 100 lbs in each cylinder....
I will agree, both should be close to the same no matter what the pressure is.
FLOATLESS Worked Great With Alky
In the OLD STOCK OUTBOARD DAYS Carter carbs worked great if the brass float seat held. Which it didn't hold very often and as a result Mercury made a "KIT" for the 20-H and 55-H. Part of the "Kit" was a Tilson carb.
What Quincy did, for ALKY RACING, and I'm not sure they did it first, was machine the bowl and a few other things out in a Carter carb, throw away the float and float seat and make a dump tube or over flow tube at the height or close to the height of a closed float.
Thew dump tube was attached to the carb bowl by a 1/4 pipe fitting that drained the bowl back into the fuel tank. This worked flawlessly as long as the return line was lower than the float over flow dump tube.
The main thing to worry in making floatless carbs was how high to make the dump tube or overflow tube. A carb and a toilet are basically the same. A floatless carb never stops running, but it doesn't matter as it has an over flow back to your tank.
This worked great for Alcohol motors as they need more fuel than gas and you never had to worry about the float seat holding in rough water.
Not sure I have this completely right, I'm sure someone will tell me the rest of the story!Last edited by Ron Hill; 11-06-2010, 08:17 AM.
Originally posted by blueskyracer View PostI gather from what I am hearing you don't use the regular factory float system with a fuel pump and seperate tank?
No changes to the carb needed.Chris Fabbro 2-F CSR / Carson Fabbro 95-F 25ssr, CSR, CSH, 300SSH / Greg Fabbro 63-F CSR, 25SSR
Originally posted by spud62w View PostI can make pretty much any kinda aluminum tank you want. I can even put it on the steering bar if you want. I'm Daves DadChris Fabbro 2-F CSR / Carson Fabbro 95-F 25ssr, CSR, CSH, 300SSH / Greg Fabbro 63-F CSR, 25SSR
Originally posted by bill boyes View PostWhy do you want to go with a floatless Carb? Many racers have gone to a fuel pump and left the carb alone.
No need the change with the pump on.
Steve A________________________
Stephen Armfield
CMH. 61R
Short Fuze Racing
IF YOU HAVE ONE LET ME KNOW
I would like to say that I wet down both cylinders over night and did another compression test and both read 118.
As for the fuel pump I guess I will have to decide if I want to add it and also add another thing that could possible break? With the short tower coming it would be nice to even get the CG lower with no tank up in the air.Mike - One of the Montana Boys
Originally posted by Chris 75F View PostI've been using the BTM system for 2 years, and it has worked perfectly.
The OEM M20H came with a regulator to prevent this.
The 80/102/302 tank sits about 6" above the carb float,
and creates about a 1/2 psi pressure on the float valve.
The BTM system pumps fuel up to the heigth of the OEM tank,
creating the same pressure on the carb, and overflows the excess.
If a floatless carb is used, there is no need to restrict pump pressure,
as the dump tube in the float bowl overflows the excess back to the tank.
This 'overflow' approach is dead simple and fool proof.
It is only legal in mod.
The BTM system works good too, but has many more parts to contend with.Brian Hendrick, #66 F
Originally posted by me-otch View PostTrue enough. But it does help lower your CG when you have the tank in the boat instead of way up high.Now if it increased power that would be another story.
