Just did a compression test on my 302 engine and the top cylinder is reading 108 and the bottom cylinder is reading 120. To me the 108 is not good.
My other question is are 102 rings the same as 302 rings? I know the pistons are different but thought maybe the rings are the same.
Are the rings and cylinder walls the only thing that could cause low compression? With a 4 stroke it could also be valves but 2 strokes to me are greek! They either run ar they don't. Building boats is much easier
Another project to add to the list!
