well since i know what class it is i wont give it away,,, mike maybe you can jump up into se/form-e with us now.....just to let you know ime just behind you on my new fe-hydro... putting on sponsons now...ie karelsen, and it big big big
Step by Step Building a hydroplane / MRC is up and running
Originally posted by daveracerdsh View PostCome on, it's Tuesday night, I am sitting around with nothing to do, nobody has *****ed at me in the last hour about commission stuff...so I am bored. What class is your sled for? Come on...come on!Mike - One of the Montana Boys
Originally posted by form-e one View Postmike ya know where i can get any 10' 6mm sheets my neck of the woods,, since it getting old joining the wood together for my afterplane uggg...Mike - One of the Montana Boys
Couple hints on applying epoxy sealer.
1. Before gluing and nailing the bottom to the stringers; pour epoxy directly on the topside of the sheet(The portion against the stringers) and use a squeegee, not a roller. I went to the local NAPA auto parts store and purchased plastic squeegees used for auto body putty. Make sure the wood is warmed up and the epoxy is slightly warm so it flows and penetrates. The squeegee allows you to control the amount of epoxy applied to the wood without excessive thickness which is added weight. You only want to seal the wood; not coat it with a thick layer. You should be able to save about 30-40% weight of epoxy using this method over the roller method.
2. You can blot excess epoxy using paper towels and blot excess epoxy. A cheap 1 inch bristle brush, with bristles cut to a remaining one inch length can be used to stipple the paper towel on flat surfaces and inside corners. Epoxy is super heavy and any glue you can remove beyond its useful purpose will reap benefits and improve the look of your workmanship.
Bob Smiley
epoxy sealer?
If you mean WEST resin or System 3 or Raka or the like, epoxy is not an actual "sealer". Epoxy allows moisture transmission. According to WEST one needs about six rolled coats of resin before to exclude moisture to an acceptable level for long term life.
Of course a race boat is not all that long term, and spends 99.9% of it's life high and dry, so I agree, forget rendering it impervious and go for flea weight. When doing 6 oz fiberglass over a cedar strip build I use squeegees, but for coating I am a roller fan. A rolled coat goes on quite thin and rarely runs or sags. Roll a coat on, tip off the air bubbles, soon as that coat gets stiff, roll on another coat, and then a third coat. Wait a week or at least 4 days for epoxy to cure out (depending on ambient cure temp), wash (to get rid of amine blush), then wet sand it with #220. Paint or varnish.carpetbagger
Originally posted by Bill Huson View PostIf you mean WEST resin or System 3 or Raka or the like, epoxy is not an actual "sealer". Epoxy allows moisture transmission. According to WEST one needs about six rolled coats of resin before to exclude moisture to an acceptable level for long term life.
Of course a race boat is not all that long term, and spends 99.9% of it's life high and dry, so I agree, forget rendering it impervious and go for flea weight. When doing 6 oz fiberglass over a cedar strip build I use squeegees, but for coating I am a roller fan. A rolled coat goes on quite thin and rarely runs or sags. Roll a coat on, tip off the air bubbles, soon as that coat gets stiff, roll on another coat, and then a third coat. Wait a week or at least 4 days for epoxy to cure out (depending on ambient cure temp), wash (to get rid of amine blush), then wet sand it with #220. Paint or varnish.Mike - One of the Montana Boys
Will the wash prevent the early sand gumming?
Bill,
Will this post cure wash eliminate or reduce the amound of paper gumming during the inital sanding. I have yet to try jumping to wet sanding so...your thoughts?
Of course a race boat is not all that long term, and spends 99.9% of it's life high and dry, so I agree, forget rendering it impervious and go for flea weight. When doing 6 oz fiberglass over a cedar strip build I use squeegees, but for coating I am a roller fan. A rolled coat goes on quite thin and rarely runs or sags. Roll a coat on, tip off the air bubbles, soon as that coat gets stiff, roll on another coat, and then a third coat. Wait a week or at least 4 days for epoxy to cure out (depending on ambient cure temp), wash (to get rid of amine blush), then wet sand it with #220. Paint or varnish.Raymond
for sure . . .
Originally posted by Raymond View PostBill,
Will this post cure wash eliminate or reduce the amound of paper gumming during the inital sanding. I have yet to try jumping to wet sanding so...your thoughts?carpetbagger
We learn something everyday. Thanks guys. When I was building a fiberglass airplane we used MC (Methelyne Chloride) to clean the waxy substance off the epoxy. Acetone was not too effective. MC is quite dangerous, so the labels say. Anyway, Thanks for your comments.
Smiley
