I guess it is time to get started on the build. First read the manual once or twice and order the material per the material list. Places are suggested to get supplies but I usually get most of my stuff from Noahs in Canada for their prices, good shipping pratices and quality.
While you wait for supplies to show up make the jig per the drawings and instructions. Spare no expense cause this is the most critical step to building a boat that will work right out of the box.
Once you get the material I lay out the coaming walls first. What I do is lay it out to where the aft part of the bottom is right along the factory edge of the plywood. Then I pin it in place with big thumb tacks so it wont move. If you look in the photo there is a tool that I call my porcupine. I got it from Tower Hobbies and it is for making R/C airlanes with monocote. I take all the blades out but one and roll it over the lines. It leaves little dots so when you take the print off you can just connect the dots with a pencil. I trace out he ribs to and then start cutting them out. Be carefull to note if you boat has an offset cockpit because half of your ribs will be an inch or two longer on the rightside. That will be the left side to start with when the boat is started out upside down.
Hopefully more tomorrow if I don't have to plow snow all day
