Wetted Surface?
  • Wetted Surface?
    Rulebook:
    Immersed Surfaces: The wetted surface of the hull, including the bottom and chines, from transom to bow.
    I assume wetted surface means ..... wet surface, when the boat is sitting in the water at legal weight ?
    Correct assumption ?
    Thanks,
    Dan
    BOPP
    Thanks,
    Dan
    Incorrect.
    If you were to flip your boat upside down and stand on a ladder directly above it, every part of the boat you see, is a wetted surface.
    I hope this makes it a little clearer.
      Originally posted by jeff55v View Post
      Incorrect.
      Even the bow that sits statically out of the water is considered an immersed surface?
      BOPP
