Fuel tank accessories
  • Fuel tank accessories
    Hoping to find some resources here. I am going to build an aluminum fuel tank for the outside rear cockpit of KT's boat. Two goals to be achieved here.
    1) take the tank off the transom so she has a little more room.
    2) expand the number area on the left side of the boat by using the outside of the tank for the number placket.
    I need options for fuel neck and caps. My neighbor owns a big chopper store, and the options that custom bikes have right now all are with vented caps. I need a non vented cap that I can install a pipe nipple and hose to vent.
    I have seen some pretty cool tanks other drivers have made, and know within the reach of this forum, someone knows where to get a good neck and cap.
    Anyone have resources or places to find what I'm looking for?
    Bill Schwab
    Miss KTDoodle #62C
    http://www.cbperformance.com/catalog.asp?ProductID=1268
    is something like this what you had in mind?
    "The Coffee Guy"
    TEAM CAFFEINE
    Cranked up and ready to Roll
      Tank Option
      In all of the A's that our family has had since the OMC(i.e. NO steering bar tanks) my dad has built "L" shaped tanks that fit on the back of the transom. The up tube extends up the transom on the inside of the clamps and ends with a cap at about transom height. The bottom section runs horizontally under the kickout bracket and ends near the outside cockpit side and ends with the pickup(which pushes the fuel to the pickup when low). They are made of 2 1\2 dia. alum. tube. They require machined pieces for the two ends but are worth it. They end up holding just under 1gal. and put all that weight as far back and as low as possible as well as move it all out of the way of your #'s and your driver. I wish I had a good pic. available, It would have shortened the explanation and made it far more clear. P.M. me if you would like more info, I'll try to help however I can.
      Dan Wilde
      58-C
      "Don't let a win go to your head, or a loss to your heart." Chuck D
        with many vented caps you can drill out the vent hole and use a nipple.
        or just fill the vent hole and vent however you choose
        "The Coffee Guy"
        TEAM CAFFEINE
          Thanks guys. Dan:
          The problem with the L shaped aluminum is that it won't work with a transom thrust jack for OMC and Merc without allot of work converting back.
          Alan Brown is sending us the bracket for the Merc to use with the thrust jack we use on the OMC.
          Kev:
          I saw that cap, I don't want a vented cap. I have found a weld in bung and non vented screw cap at a local buggy shop, it's 2 3/4" total width. I was then going to thread a nipple and run a hose just like a motocross bike uses, but am exploring most of the options first.
          This is why a steering bar tank would be ideal!
          Thanks, and Keep em, coming!
          Bill Schwab
          Miss KTDoodle #62C
            Plastic ones
            I have seen some very simple plastic square containers with a great wire bracket. Does anyone know where they came from. They look like a fluid resovour for a car or tractor or something?
            Thanks?
              We are currently using a Caterpillar tractor radiator overflow tank, all plastic, indestructible, but it mounts inside the boat. This tank is from the B series Multi-terrain loaders, and cost about $40.00.
              Bill Schwab
              Miss KTDoodle #62C
                plastic
                Dean,
                Tad Olson has a few of these, not sure where he got them though. they are ok but the snap on plastic cap ican be leaky, plus you have to be carefull with how you route the vent tube as the vent fitting is molded in pretty low and you can easily get gas coming out of the tube into the boat. they are light and inexpensive though.
                Bill
                Support your local club and local races.
                Bill Pavlick
                I'm just glad I'm not Michael Mackey - BPIII
                  Dean:
                  The overflow tanks can be purchased from your local Napa store. I have used them for Lauren's boats for years.
                  Joe
                  Thanks?
                    Fuel Cap & Filler Neck
                    Skoontz,
                    I sell a fuel cap and neck. Neck is 2 3/8 O.D. x 2" I.D. 6061 Aluminum.
                    Non vented. $35.00
                    Lee Tietze
                    Machined Components
                    Aluminum, Try Racing Without It!
                      This is where I run my tank with the AX its 2 in wide by 5 in deep and 12 in long its made with a 2 by 5 in aluminum tube and a 1/4 inch plate weld to the top and bottom of the tube. The fuel neck is just brass 1 and 1/4 id pipe with a pvc cap. Bolts right up to the back of the transom. I have another one with the same dimentions made of wood that lasted for two seasons but is giving up so have to make another one but it weights less then a pound made of wood.
                        Originally posted by Joe J View Post
                        Dean:
                        Joe
                        ADD-antifreeze/coolant tanks.
                          Auto Racing Fuel Cap Option
                          If you have a drag racing/speed equipment shop near you, many of the speed shops also sell machined aluminum, non-vented caps for fuel cells. Lee's cap is cooler looking, though...
                          Here is a website link for one of the speedshop filler cap equipment sources located in Redmond, OR: http://www.fuelsafe.com/
                          I believe they make non-vented fuel caps for filler tubes up to 3 inches.
                          Al
                            Thank you for the replies!
                            Lee:
                            How do we get a transaction done for your cap? Yours is just a tad smaller than the buggy caps and bungs available.
                            Fuel cell stuff is a great, I had looked into that....Anything that says "fuel cell" on it is an ankle holding adventure when it comes time to pay for it! But imagine...An A boat withan Arrrr Arrrr Arrrr "fuel cell"
                            Bill Schwab
                            Miss KTDoodle #62C
                              Fuel Cap
                              Skoontz
                              Call Me At my shop 503-263-2508 anytime.
                              Give me an address and I'll ship it out.
                              Lee Tietze
                              Machined Components
