No serial # = HOT! Course I have a boat trailer with no serial#, took off the sticker to paint the trailer and promptly lost it. Lost the title as well. No prob, trailer has permanent tags! Well, no prob until a cop asks me why I have an NC registered boat on a VA registered trailer being towed by an NC registered truck.
If it's an OMC, you should be able to look at the freeze plugs on the block assuming it is the factory block, and pull some numbers.
I've bought 2 engines new, had the papers, and when sold them, the tags had not been on the clamp bracket... Then I've bought used engines that the clamp bracket was changed for some reason, and the guy forgot to switch tags, so the model/serial is incorrect.....Just do your homework first.
Yes most stock "fishing" motors have the serial # staped in the block one place or another. As said OMC is ussally in a welch plug. Mercury ussually is stamped in block on top.
Steve is questioning a 302 I recently sold him. I obtained it from Pete Nydahl & he obtained it from Andrew Marquis who obtained it from a fella out of Pa. The fella from Pa. purchased it from the late Don Allen Sr.
Now Steve.... Darrell Sorenson states very few Yamatos have ID tags. As a matter a fact the other 302 in my shop does not have one nor do the
(3) 102s in the shop!
Kind of funny that it was brought to my attention that you would find something to complain about!
I think the problem was that Steve was not offered the pedigree you've presented here. Instead he got something else as a response.
