I am working on my Merc 25ss engine and need help assemblying the 3 piece flywheel. It was received in a box in 3 parts: (1)outer ring and magnets, (2)flex plate and (3) inner center piece that mounts on crank shaft that includes the recoil starter notched cup.
Since I do not have another assembled flywheel how do you determine the relative mounting position on the flex plate (2) of the outer ring (1) and the inner piece (3). The flex plate kit that I have describes that before dissassembly the relative position of (1) and (3) should be marked so reassemblly will preserve the relative position of these parts. That is great instruction if the flywheel was assembled when starting to work on!
Once assembled how do you adjust the max advance of this non breaker point magneto? I have a depth gage to set the piston to a BTDC position but after that point I am at a loss to know how to set the magneto to spark at that instant.
Any help is greally appreciated.
