Pro Motor Check valve ?????
  • Pro Motor Check valve ?????
    Last weekend in DePue. I noticed that some of you guys were using a small plastic check valve for your pressure line. Instead of the big old Koing type of check valve. Where can get these small ones at?
    Thanks,
    Mark
    Mark
    G-11
    125H
    Keep'em Sunny Side Up Boy's!
    Thanks,
    Mark
    The Thirlby automotive trailer or your local auto parts store. Straight, 100% check valve without relief. Often used on A/C systems I believe.
    David Weaver
      Ford Check Valve Info
      If you can use a full pressure check valve on your motor, I like to use Ford's Motorcraft part number DY451 (E4FZ-12A197-A) valve. Our local Ford dealer does not stock this part (not much demand for it), so I must special order the valves from Ford's central parts warehouse system through our local dealer's Parts Dept. These valves are used on Yamato and Rossi pro motors.
      Do not use the Ford check valve on a Konig. The Konig works best with the calibrated, metal can check valve (that has the adjustment screw on it) to insure the right pressure threshold (ask Ed Thirlby, I think he told me it's around 3 lb) is maintained for proper operation.
      I hope this helps you find what you want to end up using. I have tried heart surgery and equivalent GM check valves also, but the Ford valve fits the pressure feed line size I have better, has been reliable so far, and is more compact. Always cap off your pressure line when it is not attached to the tank so the valve does not collect moisture (Ed's advise).
      Al Peffley
        I buy mine from an e-bay store "advanced Research Products" They are $3.00 each plus shipping.
          Mark,
          I get mine from Cole-Parmer instruments. # EW-98553-02. Nylon body with fluorosilicone diaphragm. $3.65
          Dan
            Napa Auto Parts -- Part# 2-939 if memory serves me correctly...
              If my memory is correct, than so is yours.....
              Sattler Racing R-15
              350cc Pro Alcohol Hydro
              TEAM VRP
              The Original "Lunatic Fringe"
              Spokane Appraiser
                Been so long since you been to a race little brother that prices have gone up
                  Thirlby Automotive Trailer
                  We ONLY sell the Premium "Standard" brand of Check Valve which will cost you around 9 or 10 dollars....... Which is well worth it when you can go an entire race season on one Check Valve (For the 125cc)!
                    Thanks for all the info guys.
                    Mark
                    Mark
                    G-11
                    125H
                      Steve,
                      Get off the computer and fix my crankshaft
                      Sattler
                      Sattler Racing R-15
                      TEAM VRP
                      Spokane Appraiser
                        Yep, they are great. I have ran them also. And yes, if taken care of they should last an entire season.
                        Sattler
                        Sattler Racing R-15
                        TEAM VRP
                        Spokane Appraiser
                          Rossi
                          Rex Hall has them for the Rossi's as well.
                          What would one consider proper maintence for a check valve ?
                            No Probelm on Cost Brandon
                            I still have credits at Big Ed's shop!!!
                            David Weaver
                              Yeah, yeah... Rub it in some more. Just think of it as a year of R&D... Hope you get your 500 going a little faster, he, he heheheh.
