Gotta Q for those who know more. The boat we have is a Lovecraft, and the bottom has 5 steps from the middle to the end at the transom. So, that means, for every sheet of wood on the bottom, essentially, it raises 1/4". So, when I take a motor depth guage at 1.375 and line it up, do I simply use the last lift of wood, which is a sheet about 1'6" long, or am I required to lay the guage across the high spots of the steps through that entire 4' of bottom and use that as the basis for setting the prop shaft?
If that's what I do I need to raise the transom an inch so I can get the right motor height and still have enough meat for the turn buckles to clamp on to.
When we ran J at Parker, we were about 1/2 to 3.4" lower than we really should have been, but, that helped plane the boat off, as this boat is hard to get off plane to begin with...
Also, what brand of epoxy do I need to use to bond with the wood? And where do I get it?
Thanks in advance for any advice.
