102 Spark plugs
  • 102 Spark plugs
    Is the NKG 10 (R8102A-10) the only 18 mm plug for the 102's. I am just asking because I know nothing about this engine yet and that is what came with it. I found them at www.sparkplugs.com and they were like 10 bucks apiece. Is this the going rate for them?
    Thanks,
    Mark
    Mark
    G-11
    125H
    Keep'em Sunny Side Up Boy's!
    Yes
    or you can get a plug adaptor and run 14mm plug or buy a new head 14 mm which is what I think is best then you can run the b10egv plug much better result
      Then I will just stay with the 18mm plugs. The motor I have is a strong one and I am not changing a thing.
      Thanks for the reply Mr. Hooten
      Mark
      G-11
      125H
        102 plugs...............
        Mark, you can get the 18 MM plugs ( NGK R8102A-10 ) at Auto Parts Warehouse in California. I order them on the computor at "www.apwonline.com". Click on "NGK plugs" then type in "R8102A-10" in the search block and the plug should come up. $8.07 each. Usually takes about 3 or 4 days.
        DickTyndall 74-E
          Thanks Dick.
          Mark
          G-11
          125H
            Where can I find a 14mm head or the 14mm plug adapters?
            Ryan Runne
            9-H
            Wacusee Speedboats
            ryan.runne.4@gmail.com
              Try these guys
              Ric Montoya , Tom Johnston, Tom Cronk
              Sattler Racing R-15
              350cc Pro Alcohol Hydro
              TEAM VRP
              The Original "Lunatic Fringe"
              Spokane Appraiser
                Early 302's came with an ngk R8108-95. I have tried to locate them retail but only found the ngk R8102A-10. I did manage to get two boxes of the R8108-95 from guy that I bought my first 302 from. He worked for Chrysler and had them pouched in from Japan. George Scott 110C
                  Ryan - you may also want to try Mike Ward who is the European agent for Yamato. http://www.yamato.ndo.co.uk/
                  If you look on his Special Offers page, he mentions that 14mm heads are available http://www.yamato.ndo.co.uk/Special%20Offers.html
                    Thanks guys. Corin, Do you know what the conversion to US dollars is?
                    Ryan Runne
                    9-H
                    Wacusee Speedboats
                      Right Here
                      Ryan: Try http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
                      R-19
                      www.gleasonracing.com
                        Ryan - using today's Tourist Exchange rates, 1 USD = 0.57 GBP, so £30 equates to about $53
                          Thanks for all the help guys.
                          Ryan Runne
                          9-H
                          Wacusee Speedboats
