Any 3 cylinder OMC drivers here running a Bass tower?
Anyone here running a Bass tower on their FE/SE
Originally posted by rbenginesDavid Cleburn runs one and so does Lee Roy Keller. Sorry Cleburn's is a Mercury....
I do
I run one in SEH. The only problem I had with the tower is the exhaust location I have. Dumping out the bottom as I do I had to cut out some webbing for the pipe. No real problem. Still holds up. And you can adapt other lower units to it fairly easily.Dave Mason
Bass down housing
David if you are in the market for one I have one in my shop never been used.
It is set up for running pipes but it may be adaoptable to the exaust out the bottom. Doug SchultzDOUG SCHULTZ--HERE FOR THE SUPPORT OF OUR SPORT
Through Tower Exhaust
A couple of things you may wish to consider. We run the Tohatsu exhaust through the tower. Under the stock Tohatsu engine is an engine base that brings the exhaust to the center. If there is a similar engine base for your stock engine, chances are good that the exhaust can be easily routed through the tower. Another alternative is to route the exhaust through the side of the tower. This may require some plate and some welding. The risk is heat distortion of the tower.
Good Luck,
Neil Bass
