The cockpit of my hydro has a decent amount of offset on the left side . My question is , should the motor be centered on the transom or on the true center of the boat ? I have noticed that the left sponson seems to be riding a little low and throws up a lot of spray on the straights when conditions are calm with less lift .
offset hydro
Here's a link to previous discussion on the topic - bottomline, depends on the boat...
https://hydroracer.net/forums/forum/m...ion-on-transom
A boat will always run faster down the straightaway with the motor centered with the boat or bottom as opposed to the transom that is offset. A motor not centered puts slightly more load to the motor. May not matter in the turn but it probably will on the straights.
