I'm trying to come up with a safer approach to get a cable on the throttle linkage of a 402xs. Initially I cut a piece of brass rod with matching diameter to the round linkage piece on the engine (where barrel part of an OEM cable would go) and drilled it for bowden cable to slide through. I then tapped the end of the brass rod so a screw will hold tight. It works with boat on trailer but unsure if I trust it enough...
Does anyone know if a standard teleflex cable could be made to work by using the engine side as intended and cutting the control box end off and running into deadman, or would the diameter of the cable be too big?
