Champion Hot Rod 6N-HR L/U bearing
  • Champion Hot Rod 6N-HR L/U bearing
    Hi, Last month I found this engine in a little town here in Montana. Last run in the '60's on alcohol and castor oil, can smell it on the engine. I am looking for the bearing that is pressed on the prop shaft gear. There are no markings on it, on the parts list it is 4LS1111. Does it cross reference to a common available bearing?
    RBC 1635DSTNTG18 RADIAL BALL BEARING
    Remove any shields or seals and wash out grease in the bearing.
    Cooper Jess
      Thank you! Lot of numbers and letters!
