mod 302 LU oil fill holes
  • mod 302 LU oil fill holes
    Just wondering if someone can clear this up for me.
    Is it permissible to add oil fill/drain hole in a Yamato 302 LU in mod?
    Thanks in advance.
    Mitch Knapton 44-CE
    CMH
    Sure. It is both permissible and a good idea. You will find lobes on the inside of the gear box to provide sufficient material to drill tap and countersink the screw head.
