Looking for some pics of the throttle brkt that was installed on the left side of the motor. I have a new bracket and all the hardware but not sure how to hook up the carb linkage. I took off the butterfly and thought I could just swap it from one side to the next but I guess I have to do some mods. What needs to be done?? What orentation does the throttle on the carb need to be in?? Up or down?? And do I need to grind the steel piece off the brass shaft to make it work and how?? I now have the old style set up that mounts to the lower cowl but you all know they suck because you give it throttle and the lower cowl moves too... Please Help!!!!
