I purchased a GRM 125cc powerhead from Brennan a few years ago (a prior Team Thompson motor?) with a quick disconnect fitting on the cylinder head that has the same metric threads as those in the GRM water cooling inlet hole (I think the threads are 10mmx1.00, or close to that pitch.) Even though the threads look similar, I know that this special fitting's threaded hole is slightly smaller than a US SAE 1/8" pipe threads male fitting.
The quick disconnect fitting has "PRESTOLOK" and "5/15" stamped on the black quick disconnect collar (it fits 5/16 plastic air line.)
I would like to buy two more of these fittings for my GRM 250cc powerhead to replace the OEM collar-tightened fittings for flared plastic lines. Does anyone know where I can buy these aftermarket quick disconnect air fittings. None of the Parker air/hydraulic line hardware shops around my area have metric elbows like this fitting.
The fitting is a 90-degree elbow with what looks like "C8" stamped on one side and made out of what looks like a stainless steel alloy. I can send someone a digital picture of the specialty fitting if they know something about these fittings and a source for them. Thanks, in advance, for your help in this matter.
Al Peffley
Cell: (206) 406-4996
Email: team_excalibur@hotmail.com
Al Peffley
