I am trying to put together a evinrude "A" engine from parts aquired and am in need of some info/help ?? Can anyone tell me if there are solid mounts made for this motor ? OR - I have seen some assembled with a stainless steel cupped washers bolted on both sides of each mount to keep them solid , anyone know where i can find some of these ?? ALSO , i see in the A specs there are certain part #s that have to be on some parts . I have a block , head , and carb , but as far as the exhaust covers , transfer port cover , flywheel , and intake , can anyone tell me if any of part #'s work better than others ?? Any help is greatly appreciated & it would make the search much easier ! THANKS !! PAUL - JEEPKREEP@AOL.COM
Evinrude/Johnson 15 "A" Info/Help needed !
