throttle cable
  • throttle cable
    I am in the final stages of restoring my Furnel Flyer. Is it best to use a graphite powder to lube the throttle cable or put it together dry? Thanks
    Run some WD40 through the outer housing without the wire inside. Do this regularly and you shouldn't have any trouble with the cable ever getting sticky. You might be amazed to see how much crap flushes out when you do this.
      throttle cable
      That is exactly what I do and the cable works well.
