Need DVA meter at Hillsdale
  • Need DVA meter at Hillsdale
    I need a DVA meter at Hillsdale! If you have one can you can bring it? I will give you a surprise. (you can help me check my 44xs parts)
    Brian what is a DVA meter. Are you talking about a digital volt and amp meter
    if so I have one and can bring it.
    David Everhart
    s52
    David Everhart S52
    Avatar credit - F. Pierce Williams
      DVA Explained
      DVA stands for Direct Voltage Adapter, which is used to measure peak AC voltage. This type of measurement of AC voltage takes the absolute peak or highest value of the fluctuating AC voltage signal. Peak readings will be substantially higher than standard or RMS AC values and are typically used when testing marine CD (capacitor discharge) ignition systems due to their high variance in frequency as RPM increases and decreases.
      An example would be that the typical RMS AC reading of a wall outlet in North America is
      120V. However, a DVA measurement of this same AC voltage would reveal that the peak of the AC sine wave is typically between 160-170V.
      Some meters are capable of reading DVA or peak voltage pulses. Many ignition system
      components produce short AC voltage pulses. A peak-reading analog meter or DVA adapter
      plugged into a digital meter captures and holds the peak value of an AC sine wave long enough for the human eye to see it displayed on the meter. A conventional meter is incapable of accurately measuring these short-duration voltage pulses. A peak-reading voltmeter has special circuits that allow the meter to capture the maximum voltage produced during these short duration pulses and display the voltage as DVA or peak voltage. Failure to measure DVA can cause good ignition components to be incorrectly diagnosed as faulty.
      The only meters that have built-in peak reading capabilities are analog meters with built-in DVA. Digital meters do not have built-in peak reading capabilities. In order for a digital meter to read peak voltage, one will need a DVA adapter, such as CDI part# 511-9773 or 511-9773NL.
      Using a DVA adapter, a digital meter must be set to its DC voltage scale. Peak AC voltage is the measurement, but the DVA adapter has a built-in bridge rectifier, which converts AC to DC. The DC voltage setting on a digital meter is required to accurately read DVA.
        I have 2.....
        http://www.stevensinstrument.com/peak_dva.htm
        Good investment.......I won't be @ Hillsdale.
        17W
          rapair/cdi sells one plug directly into a volt meter use it all the time at the marina give them a call... they also on the net
