I have a stock 1973 Merc 25ss with cd ignition. Is there a way to set the timing without a timing light and creating BTDC degree marks on the flywheel rim and a reference pointer at TDC?
Would like to use a procedure of the piston location at the proper position before TDC rather than the engine running with the timing light. What do the Y302 guys do? I have a buzzer box and dial indicater that I use for the Y80 and realize the buzzer box is only for breaker point ignitions. Need to get this engine on the
and play.
