I use a boat bailer pump that runs off of 12 volts . Hook up the hose from the pump to the hole where the brass fitting is on the back of the downhousing. Tape over the holes on the regular pick up so the water runs through the engine and not out the pickup holes. You could simply use a garden hose instead of the pump but keep the pressure low. Jack
