Yamato pro foot questions
  • Yamato pro foot questions
    I have a couple of questions... I have a new style case horizontal split 1 piece drive shaft pinion gear.
    1. Any secrets to pressing on the gear to the shaft. Just match the gear to the raised section?
    2. Anyone have all of the bearing a seal numbers in a list. I have a couple of them.
    3. Has anyone used shorter needle bearings in the front of the case. example I found bearings online that are 15mm long not the 16 and 20mm called for in the case. Crazy cheaper than the 20mm long ones.
    4. Anyone have a case with dead gears and good case. I still have some friends looking. I found 1 but I need two more.
    Just trying to get ready before the season starts.
    Brian
    A suggestion
    Brian,
    Send your questions to Mike Schmidt. I believe that he helped Noah with his lower units!! Good guy and a wealth of knowledge.
    DW
    David Weaver
