The height will most effect speed however the hi-er it is the less leverage is applied to bow lift. The porpoising is controlled by tilt angle. Getting them right at the same time is where youll see a big difference.
The boats being faster tilted out and bouncing is a sign that the motor and prop are trying to break free & run but at what cost to structural integrity?
I think it should be running an inch deep kicked in some then determine tilting in more or not. A balance between fast enough and ability to handle would be great but theres always trade off in my experience.
If your racing a class you can look, ask around and see how the others are performing, when setting up a play boat your guessing more. At present speed trim tabs will help tame it but wont be likely to make it faster, props, set-up & tuning are what will get you to the boats potential speed. It should be able to reach into the 50s unless its real heavy or somethings wrong.
It would seem on a tunnel that the optimal height is variable. to say it rides on the surface at the sponson rear is dependent on enough speed to get it there. If at 45mph it isnt on top then effectivly the props too deep. Id think small changes will help, like raising a 1/4" at a time, and going to slightly less than parallel.. the prop sending thrust down to give some lift to the transome.
