Mercury C and D parts
  • Mercury C and D parts
    Mercury C parts
    New:
    Prop Shaft
    Gears
    Water Pump, impeller, and seals
    Used:
    3 gear cases: 1 large skag, 1 small skag , and 1 small skag repaired
    cone nuts
    Quicksilver exhaust housing
    water pump housing and nut
    shims
    drive shaft
    water tube
    Mercury D parts
    1 complete Hydro Short Quicksilver with new prop shaft, bearings and seals
    1 D Hydro Quicksilver housing
    gear case
    cone nut
    drive shaft
    1 new prop shaft
    3 used bearing cones
    3 used prop shafts
    2 used water pump housings
    3 new water pump seals
    1 like new bearing cone and water pump housing
    2 used pinion gears
    2 used ring gears
    3 used cone nuts
    Miscellaneous
    1 D test wheel
    1 C test wheel
    steering bar
    racing throttle
    cone wrench
    seals(new) Chicago Rawhide: #s 6220 (3)
    5522 (2)
    7414 (2)
    6147 (1)
    $1500 for all
    Contact Ed Blake @ 937-609-4289
    ed sent you a and also a voicemail.
    frank novotny
    52-E
      Sale Pending
