Refurbished 4 place trailer and untouched/fresh Yamato 302 -$4000
  • Refurbished 4 place trailer and untouched/fresh Yamato 302 -$4000
    Trailer has are two hidden storage compartments below the bottom bunk that are perfect for storing things like extra windscreens, ballast weights. There are the provisions for two external one place motor boards located port and starboard at the front edge of the motor box.
    Yamato 302 has one light season on it since purchased new from TJ.
    This Trailer and Motor Package Includes:
    Large Float Coat
    Boat cart
    Height and trim set up tools
    Test Prop
    Kick Brackets
    7/16 Restrictor
    Miscellaneous stainless nuts, bolts, washers & screws, spark plugs, boat plugs, prop pins, carabiners, kill switch, tiny tach, lead ballast weights.
    Spare Throttle, Helm Drum and Wheel, Fin Bracket, Fin, Fairleads, Duckbill syphon
    Marine speedo
    Johnson/Evinrude OEM 9.9 – 30 Service Manual
    Located in SW Michigan
    Raymond
    Sold. Thanks for all the inquires.
    Raymond
