Yamato Pro Motor & Boat Parts Liquidation Sale
  • Yamato Pro Motor & Boat Parts Liquidation Sale
    The Yamato Factory will be liquidating it's Pro Motor and Boat parts in July 2016. I'll take orders till June 15th, I'll then place a request for the items you want and have it all shipped here (Seattle) all in the same shipment.
    If you know of other racers looking for any of this, please pass this along.
    I'm sorry I don't know what exact model years these parts are for. Hopefully one of you might.
    Ric Montoya - RPM Marine - 206-283-4773 - ricstr4@gmail.com
    Special Price of The Racing Motor Parts till 6-15-16
    Yamato Motor Co., Ltd.
    Part No Description Amount in stock Special price
    005-0400610 Bolt4×6 48 0.49
    005-0601010 Bolt6×10 50 0.49
    005-0601410 Bolt6×14 1278 0.49
    005-0601510 Bolt6×15 379 0.49
    005-0602010 Bolt6×20 482 0.49
    005-0602510 Bolt6×25 193 0.49
    005-0809510 Bolt8×95 22 0.58
    006-0602901 Stud6×29 180 3.68
    006-0603500 Stud6×35 222 1.82
    006-0802400 Stud8×24 97 2.40
    006-0802800 Stud8×28 39 2.48
    006-0802900 Stud8×29 50 2.00
    006-0803800 Stud8×38 51 2.00
    006-0806501 Stud8×65 280 2.74
    006-1005700 Stud10×57 76 5.58
    006-1205800 Stud12×58 66 5.78
    014-1231300 Nut M12 342 0.49
    024-0502104 Propeller Pin5×26 123 0.88
    025-0200400 O-Ring2.0×39.5 45 1.06
    025-0200560 O-Ring2.0×55.5 92 1.46
    025-0200630 O-Ring2.0×62.5 63 7.36
    025-0350560 O-Ring3.5×55.6 4 1.48
    026-1201530 Inner Race φ12×φ15×L22.5 27 6.42
    026-1502310 Needle Roller Bearing TAF152316 7 18.72
    026-1502311 Needle Roller Bearing TAF152320 3 22.12
    026-1502411 Needle Roller Bearing TR152425E01 16 50.40
    026-1502890 Thrust Bearing φ15×φ28×t2 6 7.26
    026-1502891 Thrust Bearing φ15×φ28×t2.75 8 7.80
    026-1503503 Ball Bearing 7202CP5 1 34.44
    026-2403211 Needle Roller Bearing SKTZ243216EGS02B2 419 23.10
    026-2506200 Ball Bearing 6305 25 6.18
    026-3006201 Ball Bearing 6206 7 6.10
    026-3006202 Ball Bearing 7206CP5 4 31.50
    026-3504210 Needle Roller Bearing KT354216 26 40.00
    028-2540083 Oil Seal FPJ25408 135 2.32
    028-2545110 Oil Seal AC1338A0 60 3.68
    033-1602300 Power Band φ16 11 0.64
    300-1160000 Connecting Rod RA-1 98 66.78
    300-1310002 Piston RA-1 7 6.30
    301-1310000 Piston RA-1 25 10.30
    301-1540000 Cylinder Head Assy RA-1 1 107.32
    301-3870002 Intake Manifold Assy RA-1 3 60.14
    301-3880001 Gasket-Intake Manifold RA-1 60 0.60
    301-4620000 Rubber Flange Adapter RA-1 3 16.80
    302-1100000 Crank Shaft Assy RA-1 1 1512.00
    303-1010000 Center Bearing Outer Race φ42×φ62×L18 RB-5 187 48.30
    303-1320000 Piston Pin RB-5 300 4.00
    303-1340002 Spacer t1.0 Piston RB-5 31 2.22
    303-1340003 Spacer t1.1 Piston RB-5 9 2.22
    303-1350000 Piston Ring RB-5 76 10.84
    303-1540000 Nipple M6 RB-5 134 0.80
    303-1820000 T Connecter RB-5 5 5.04
    303-2380000 Starter Pulley RB-5 1 79.80
    303-2950000 Stator RB-5 16 266.50
    303-4030000 Fuel Pipe Connecter RB-5 14 13.66
    303-4050000 One Way Valve RB-5 73 8.62
    303-6320000 Spring Washer M14 RB-5 76 0.20
    304-1310001 Piston (LATEST TYPE) RB-5 60 73.50
    304-2410001 Housing CDI RB-5 6 38.86
    304-2510000 Stator Housing RB-5 4 116.00
    304-2560000 Flywheel RB-5 1 420.00
    304-2580000 Ignition Coil With Two Plug Cord RB-5 9 31.50
    304-2630000 CDI Controll Unit RB-5 12 504.00
    304-2670000 Tacho Meter Cord RB-5 28 63.00
    304-3280000 Pulse Chamber Stay('90model) RB-5 4 220.50
    304-3290000 Pulse Chamber Stay(Lower) RB-5 4 52.50
    304-3360000 Stay Ring For Pulse Chamber With Silencer RB-5 7 56.70
    304-3430000 Pulse Chamber (Front) RB-5 1 483.00
    304-3440000 Pulse Chamber (Rear) RB-5 1 483.00
    304-3630000 Pulse Chamber With Silencer(A) For No.1,4 Cylinder RB-5 1 651.00
    304-3640000 Pulse Chamber With Silencer(B) For No.2,3 Cylinder RB-5 1 651.00
    304-3720000 Pulse Chamber Stay(1) RB-5 5 52.50
    304-3750000 Pulse Chamber Stay(4) RB-5 3 44.10
    304-3760000 Pulse Chamber Stay(5) RB-5 6 73.50
    304-4410000 Intake Manifold(A) RB-5 15 21.66
    304-4420000 Intake Manifold(B) RB-5 12 134.00
    304-4620000 Gasket-Intake Manifold RB-5 21 0.49
    304-4840000 Gasket-Valve Plate RB-5 12 0.49
    305-1450000 Piston Ring-Oversize RC-5 200 9.04
    306-1320000 Piston Pin RC-5 270 11.56
    306-1330000 Pisotn RC-5 26 35.34
    306-1620000 Cylinder Head Assy RC-5 7 243.98
    306-1630000 Intake Manifold(A) RC-5 7 80.02
    306-1640000 Intake Manifold(B) RC-5 7 80.02
    306-2130200 Stator(RC-5) RC-5 2 147.38
    306-2510000 5 Stator Housing RC- 5 116.00
    306-3500000 Pulse Chamber Slide Cable Connector Assy RC-5 2 293.90
    306-5000000 Bracket Assy RC-5 1 1446.20
    306-5100000 Drive Shaft Housing Assy RC-5 4 439.32
    306-5400000 Sterne Bracket RC-5 3 97.22
    306-6110000 Gear Case Set RC-5 3 660.00
    306-6160000 Propeller Shaft Set RC-5 12 190.00
    306-6170000 Propeller Shaft Collar RC-5 28 8.40
    306-6190000 Needle Roller Bearing Stopper RC-5 20 6.30
    306-6250000 Gear12:15 RC-5 4 157.50
    306-6340000 Pinion Gear13:15 RC-5 20 156.46
    306-6360000 Gear13:15 RC-5 16 95.56
    306-6440000 Pinion Gear14:15 RC-5 9 111.10
    306-6460000 Gear14:15 RC-5 5 73.30
    306-6540000 Pinion Gear14:14 RC-5 17 120.76
    306-6550000 Gear14:14 RC-5 16 66.16
    Special Price of The Racing Boat Parts till 6-15-16
    Part No. Description Amount in stock Special price
    378-0302010 Throttle Cable Outer L2500 9 29.40
    378-0323010 Fin 7 75.60
    378-0323020 Bracket 28 83.36
    378-0402000 Drain Plug 26 8.82
    378-0901010 Brake Disc(Steering) 19 56.70
    378-0901020 Stay(Steering) 21 10.50
    378-0901030 Upper Arm(Steering) 21 10.50
    378-0901040 Lower Arm(Steering) 21 10.50
    378-0901050 Brake Pad(Steering) 34 7.14
