Revised Engines And Parts For Sale List
  • Revised Engines And Parts For Sale List
    FOR SALE - STOCK, MODIFIED AND ALKY RACING ENGINES & PARTS. *NOTE: All sales transactions are in USD$ Dollar funds only because that is the way they were purchased to begin with. The list As Follows: Numbers of sales items are subject to change without further notice from this date of posting.
    *1 each (2) of British Anzani collector's Alky engines, one each "A"(15 cube) -Alky and one B-(20 cube) Alky. Engines come with a single Alky hydro 2 blade prop each. Open to offers on one or the pair of engines.
    *Quincy Flathead Looper Class "D" - 4 cylinder 40 cubic inch collector's Alky engine. Serial No. FD40 Engine comes with a single tulip eared 3 blade racing prop. Open to offers on the engine.
    *1 of ready to run on your hydro - Mercury 55H-1 type D-Modified 40 cubic inch racing outboard. Mike Franck originally built and very fast engine. Quincy manufactured/welded midsection tower, Merc KC carbs (upgraded to), P4D Merc magneto ignition, Bayer all aluminum pro-cast and finished 2 into 1 - 4 cylinder racing stack set, button light flywheel/rope starting plate (upgrade) and Mercury Quicksilver "D" - 1 to 1 ratio gearcase/lower unit. $2,500.00 plus shipping costs. *Add $200.00 for its 4 blade propeller.
    *1 of ready to run on your FE hydro - Mercury 500 type wide port Formula E Modified 44 cubic inch racing outboard. Very fast engine. Quincy manufactured/welded midsection tower, Merc KC carbs, P4D Merc magneto ignition, Bayer all aluminum pro-cast and finished 2 into 1 - 4 cylinder racing stack set, button light flywheel/rope starting plate and Mercury Quicksilver "D" - 1 to 1 ratio gearcase/lower unit. $2,500.00 plus shipping. *Add $200.00 for its 4 blade propeller.
    *6 of Merc stock bore 44 cubic inch seasoned blocks with minimum bore stock bore wear. $50.00 each plus shipping.
    *6 of Merc stock bore nearly new (cleaned) big wrist pin - pistons (1st generation lighter version). $50.00 each plus shipping.
    *4 of Merc 1st generation large wrist pin connecting rods, all honed to remove over tightness. $25.00 each plus shipping.
    *4 of Merc stock bore second generation large wrist pin nearly new and cleaned, 3, ring pistons (generation used with the newest generation of large wrist pin, fractured connecting rods associated with 2nd 3 ring and 3rd generation 2 ring pistons. $75.00 each plus shipping.
    *4 of newest generation of Merc 44 fractured type connecting rod with cap bolt using larger wrist pin type pistons, honed to relieve “over tightness” - typically used with 2nd 3 ring and 3rd generation 2 ring pistons. $50.00 each plus shipping.
    *6 of Mark 30/Mark 55 brass cast, smooth crankshaft bore, reed blocks with smaller openings reed petals. Smaller stainless steel reed petals installed. $20.00 each plus shipping.
    *2 of Mark 55H brass cast reed blocks with typical smaller reed petal openings, stainless steel reed petals installed. $50.00 each plus shipping.
    *2 of Merc 500 brass cast reed blocks with larger reed petal openings with composite reeds installed. $150.00 for the pair and only sold as a pair.
    *8 of Mercury Mark 58 through 500 wide taper top crankshafts checked and guaranteed straight. $75.00 each plus shipping.
    *6 of Merc Mark 30H/Mark 55H magneto adapters with shafts and magneto belt pulley parts. $40.00 each plus shipping.
    *3 of Quincy for Mercury 30H/55H/Mark 58 and 500s complete 4 cylinder coupled twin exhausts systems (includes filler block and water tube). $400.00 per complete exhaust system plus shipping.
    *2 of Quincy welded stick/pipe type steel midsection towers, Merc saddle, Merc clamps and co-pilots installed. $250.00 each complete tower plus shipping.
    *1 of noted race engine and part builder Ray Nydahl build class F Alky or FE/SE Modified custom made tower housing for Mercury Mark 75H, 78H (60-66 cube) , Quincy Flathead Loop - all 6 cylinder engines as well as the Mercury 650 (60-66 cube) - 4 cylinder engines. Comes with all components including the matching steering bar and Konig transom clamping system. Uses Konig D-F Alky racing gearcase/lower unit (not included) $400.00 plus shipping.
    *1 of Parker thick cast aluminum racing tower with Mercury clamps. Very nice finished and threaded for use casting with water level snout exhaust. Bolts up with Speedmaster racing model gearcases. Block bolt pattern fits all early big Mercury 4 and tall 6 cylinder Merc engines through to earliest V-6 Merc tunnel boat engines. $400.00 plus shipping.
    *4 of Mercury NOS (new) small wrist pin standard bore 3 ring pistons. $75.00 each plus shipping.
    *4 of Mercury NOS (new) Mercury 30H late model flat top stock bore racing pistons with new rings, wrist pins and wrist pin clips. Can also be used in KG-4H and Mark 15 Merc racing engines and well as fishing engines. All 4 to be sold as a block for $300.00 the full set of 4 plus shipping/mailing cost.
    *4 of Turner (used) high dome Modified or Alky racing pistons with smaller wrist pin for earlier Merc 22 and 44 cubic inch applications. $55.00 each plus shipping.
    *4 of Turner NOS (new) high dome Modified or Alky racing pistons with smaller wrist pin for Merc 20/40/60 applications. With new rings, wrist pins and pin clips for $400.00 for the set plus shipping.
    *Miscellaneous new Turner piston rings made from various metals for Merc 20/40/60 and 22/44/66 cubic inch applications. $8.00 per "new" piston ring plus shipping.
    *1 of Parker Racing Exhaust set, nearly complete Merc 4 cylinder 2 into 1 exhaust system. Only missing tapered bell stacks and their retained springs. $250.00 plus shipping.
    *1 of LeBanco Racing Exhaust set, nearly complete Merc 4 cylinder type with Wienandt side plate, 2 into 1 type exhaust system. Only missing the 2 bells or in this case where expansion chambers used, both expansion chambers are missing. These particular pipe parts are sought after by Merc 30H users arming their engines with custom made expansion chambered stinger pipes. $250.00 plus shipping.
    *14 complete Merc fuel pumps as used on Mark 20H, Mark 30H and Mark 55H and other earlier Merc 44 applications. All have good valves but need new diaphrams. $10.00 per pump plus shipping.
    *Complete Mercury/Tillotson KA carbs. (sold as pairs only). $50.00 a pair plus shipping.
    *Complete Mercury/Tillotson AJ carbs. (sold as pairs only). $40.00 a pair pair plus shipping.
    *Complete Mercury/Tillotson KC carbs from Merc 650 - 4 cylinder engines. (sold as pairs only). $80.00 a pair plus shipping.
    *2 of Hopkins stainless of Merc 55H D Stock Hydro long course 2 blade propeller. For a 2 blade this one is exceptional. $120.00 EACH plus shipping.
    *1 of Keller hydro/runabout racing throttle. $75.00 plus shipping.
    *5 of Mercury P4D overhauled and setup complete & ready (caps, sparkplug wires and all) to use magnetos for Merc 4 cylinder engine applications. $125.00 each per complete magneto plus shipping.
    *6 of Mercury aluminum reed blocks with good center bore crankshaft labyrinth seals. $50.00 per pair with reeds and stops plus shipping.
    *19 of Mercury 600-4 small wrist pin connecting rods. All gram weighed and marked. All honed to same specs to remove crankshaft over tightness. $20.00 each per connecting rod plus shipping.
    *1 of Quincy type 600-4 small wrist pin Alky use connecting rod. $40.00 plus shipping.
    *2 sets left of 12 rings each of NOS (new) Merc standard bore ring sets for Merc 22/44 cubic inch applications. $80.00 per set of 12 new rings plus shipping.
    *5 of extra Quincy Modified/Alky exhaust chamber Mercury 4 cylinder type filler blocks (both new (unfitted or trimmed) and used) for Mercury 4 cylinder (30, 40 & 44 blocks), for more modern 2 into 1 and 4 individual stack systems as well as different filler blocks for older blocks as well as newer - 1 type. Its your measurement that counts, no returns at $75.00 each plus shipping.
    *1 of large Racing Runabout bottom skeg casting. $50.00 plus shipping.
    *6 of Quincy Flathead dry as well as water injected cast aluminum exhaust elbos at $100.00 each plus shipping.
    *2 of finished casting aluninum cast surplus Quincy straight taper exhaust bell(s) earlier model for the Flathead Alky Loopers. $100.00 each plus shipping.
    *2 of finished surplus Quincy "exponential mult-tapered" later model exhaust bell(s)for the Flathead Alky Loopers. $100.00 each plus shipping.
    ALL SALES ARE IN USA$D DOLLAR FUNDS
    All purchases are "As Is". Shipment insurance costs are extra as are shipping costs. *Due to age of parts, insurance may no longer be available through freight carriers. Purchases "will be by international money orders or cashiers cheques paid in USA$ Dollar funds" Personal cheques will be returned immediately without processing. Payments before shipping will be verified before shipments take place. There will be no shipments carried out in trust while supposedly full payments are in the mail.
    Interested? email me, John Taylor at: anzani@mts.net
    Telephone me evenings at: (204) 667-3815.
    Prices are just that, prices, all offers will also be considered.
    These Quincy Flathead Loop and British Anzani racing engines can be viewed at Ted March and Ron Hill's boatracingfacts.com website and following their internal links to all the areas featuring these engines.
    *I take JPeg digital pictures of engines and parts purchasers are interested in for email transmission.
    Revised Race Engines And Parts For Sale - Nov.10, 2005
    *1 each (2) of British Anzani collector's Alky engines, one each "A"(15 cube) -Alky and one B-(20 cube) Alky. These are the 2 cylinder loop charged, rotary valved outboard racing engines Engines come with a single Alky hydro 2 blade prop each. Open to offers on one or the pair of engines.
    *Quincy Flathead Looper Class "D" - 4 cylinder 40 cubic inch collector's Alky engine. Serial No. FD40 as designed and built by O.F Christner and the Quincy Welding and Machine deam team starting in the mid 1960s. This one has all the latest bells and whistles from its L-ringed flattop pistons, all Quincy crankcase & block, T type transfer ports, water injected exponential stacks that will get you jailed if you start/run it in the same place too many times. It is quite capable of speeds exceeding 100 mph. If you can and they did run a dozen of these per heat in elmination heats in their heydays starting in the mid 1960s. Engine comes with a single tulip eared 3 blade racing prop. Open to offers on the engine.
    *1 of Mercury 55H-1 type D-Modified 40 cubic inch racing outboard. Mike Franck originally built and very fast engine. Quincy manufactured/welded midsection tower, Merc KC carbs (upgraded to), P4D Merc magneto ignition, Bayer all aluminum pro-cast and finished 2 into 1 - 4 cylinder racing stack set, button light flywheel/rope starting plate (upgrade) and Mercury Quicksilver "D" - 1 to 1 ratio gearcase/lower unit. $2,500.00 plus shipping costs. *Add $200.00 for its 4 blade long oval course propeller.
    *1 of Mercury 500 type wide port Formula E Modified 44 cubic inch racing outboard. Very fast engine. Quincy manufactured/welded midsection tower, Merc KC carbs, P4D Merc magneto ignition, Bayer all aluminum pro-cast and finished 2 into 1 - 4 cylinder racing stack set, button light flywheel/rope starting plate and Mercury Quicksilver "D" - 1 to 1 ratio gearcase/lower unit. $2,500.00 plus shipping. *Add $200.00 for its 4 blade long course propeller.
    *** Important Question***?*Asked if I would change over from Formula E Merc 44 block to D-Modified Merc 44 block to run as a D-Modified instead? Answer is - Yes! *No change in price be it an FE or changed with a fresh 44 cubic inch block and internals to a D-Mod.
    *2 of Quincy for Mercury 30H/55H/Mark 58 and 500s complete 4 cylinder coupled twin exhausts systems (includes filler block and water tube). $400.00 per complete exhaust system plus shipping.
    *1 of Quincy welded stick/pipe type steel midsection towers, Merc saddle, Merc clamps and co-pilots installed. $250.00 each complete tower plus shipping.
    *Miscellaneous new and used Turner piston rings made from various metals for Merc 20/40/60 and 22/44/66 cubic inch applications. $8.00 per "new" piston ring plus shipping. Good but little used rings $3.00 each plus shipping.
    *1 of Parker Racing Exhaust set, nearly (incomplete) complete Merc 4 cylinder 2 into 1 exhaust system. Only missing tapered bell stacks and their retained springs. $250.00 plus shipping.
    *1 of LeBanco *Complete Racing Exhaust System for Merc 4 cylinder types with Wienandt side plate, 2 into 1 type exhaust system. The 2 bells *are found! Builders use this system where expansion chambers can be fitted as alternative to bells. These particular pipe parts are sought after by Merc 30H users arming their engines with custom made expansion chambered stinger pipes. $250.00 plus shipping.
    *12 complete Merc fuel pumps as used on Mark 20H, Mark 30H and Mark 55H and other earlier Merc 44 applications. All have good valves but need new diaphrams. $10.00 per pump plus shipping.
    *3 pairs of Merc 400-450-500 early version engine miscellaneous pairs of complete Mercury/Tillotson KA carbs. (sold as pairs only). $50.00 a pair plus shipping.
    *2 pairs of complete Mercury/Tillotson AJ carbs. for Mark 30s, Mark 55s and 55A & 55AEs (sold as pairs only). $40.00 a pair pair plus shipping.
    *2 of Hopkins stainless of Merc 55H D Stock Hydro long course 2 blade propellers. For a 2 blade they were good to exceptional. $120.00 each plus shipping.
    *4 of Mercury aluminum reed blocks with good center bore crankshaft labyrinth seals. $50.00 per pair with reeds and stops plus shipping.
    *14 of Mercury 600-4 small wrist pin connecting rods. All gram weighed and marked. All honed to same specs to remove crankshaft over tightness. $20.00 each per connecting rod plus shipping.
    *4 of extra Quincy Modified/Alky exhaust chamber Mercury 4 cylinder type filler blocks (both new (unfitted or trimmed) and used) for Mercury 4 cylinder (30, 40 & 44 blocks), for more modern 2 into 1 and 4 individual stack systems as well as different filler blocks for older blocks as well as newer - 1 type. Its your measurement that counts, no returns at $75.00 each plus shipping.
    *Lots of "New" whole boxes of Champion "L" type "R" for racing spark plugs for Quincy, Konig, Yamato etc. Alkys. $5.00 a sparkplug plus mailing costs.
    *Some versions of "New" AC outboard racing sparkplugs for Merc and OMC's at $5.00 a sparkplug plus mailing costs.
    If there is a sparkplug or part not specifically listed here, it is okay to ask the question in email or by phone. I will find out and answer.
    ALL SALES ARE IN USA DOLLAR FUNDS AS THAT IS HOW THEY WERE ALL PURCHASED TO BEGIN WITH. All purchases are "As Is". Shipment insurance costs are extra as are shipping costs. *Due to age of parts, insurance may no longer be available through freight carriers. *Purchases "will be by international money orders or cashiers cheques paid in USA$ Dollar funds" *Personal cheques will be returned immediately without processing. Payments before shipping will be verified before shipments take place. *There will be no shipments carried out in trust while supposedly full payments are in the mail.
    Both collectors and racers are very welcome.
    These Quincy Flathead Loop and British Anzani racing engines can be viewed at Ted March's and Ron Hill's boatracingfacts.com website and following their internal links to all the areas featuring these engines.
    *I will take JPeg digital pictures of engines and parts purchasers are interested in for email transmission
