Even with my non-standard approach you guys helped a ton (even if mostly from the search!) with getting this build done. Hoping to find a good home for this cool custom boat with someone who can appreciate it! I'd have a hard time selling this to someone who wasn't going to treat it with respect. At the same time it is not a class racer anymore so hopefully I'm not offending anyone by offering it for sale here.
Boat is located in Portland, OR.
I bought this boat eight years ago from the builder's son who said he raced it in the 60's. I wanted a super unique and fast recreational boat. With that in mind I had a custom aluminum transom built to accommodate a Yamaha 30hp oil injected short shaft outboard. This allowed neutral, electric start, reverse and rack and pinion steering. All convenience and safety features you obviously don't find on these boats in race configuration. The stainless steel prop is custom from Ron Hill Marine. I have the motor sitting a few inches lower than ideal for speed. It still hits 45 MPH on GPS and am told is good for at least 60 MPH with a low water pickup and bringing the motor up a bit. It is surprisingly comfortable to drive and very confidence inspiring. All seams on the boat and potential spots for water intrusion were sealed with 2-part epoxy before prep and paint with the best quality marine paint, Pettit EZPoxy, to prevent water damage to the beautiful hardwood construction. This boat turns every head on the water or on the trailer. Will safely float two people total weight around 350 lbs at a standstill. You'd be hard pressed to find a cooler water toy. Includes trailer with LED lights, fresh wheel bearings and bearing buddies.
$2450
Contact Tom at 5O3-7O5-8239 or E-mail hi0npsi@hotmail.com. I will do my best to check the forum as well. Thanks!
$2450
