Where do I get parts for the power head? Any racers in the northeast dealers? Gonna need a fuel pump soon.
OMC J15 parts?
http://www.ebay.com/itm/6-18-20-25-h...51111851296%26 ...used
http://www.ebay.com/itm/NEW-Fuel-Pum...359d2a&vxp=mtr
http://www.ebay.com/itm/new-Marine-F...60629771562%26
http://www.ebay.com/itm/OMC-Johnson-...5a888e&vxp=mtr
http://www.ebay.com/itm/SIERRA-FUEL-...10849270619%26
http://www.ebay.com/itm/NEW-SIERRA-1...60629771562%26
http://www.ebay.com/itm/Johnson-Evin...50783893021%26 ...New/BRP
http://www.ebay.com/itm/Johnson-Evin...90858514021%26 ...New/BRP "with all the latest updates and materials for todays high alcohol fuels." (...Not sure what that means??)
http://www.ebay.com/itm/New-Johnson-...50782079059%26 ...NOS
http://www.ebay.com/itm/New-Johnson-...90858514021%26 ...NOS
http://www.ebay.com/itm/397445-03974...84b665&vxp=mtr ...NOS
http://www.ebay.com/itm/FUEL-PUMP-RE...21239187471%26 ...NOS
http://www.ebay.com/itm/NEW-SIERRA-1...10849270619%26
http://www.ebay.com/itm/OMC-393088-0...e2180f&vxp=mtr ...NOS
Yah, Way too much time on my hands.....Can't sleep, or git too far from the toilet>> (Think I got some bad wings at the local water'n hole).Last edited by STEVE FRENCH; 07-05-2013, 02:35 AM.100N STEVE FRENCH > Nobody can hang with my STUFF!! >> http://www.youtube.com/watch?v=tna3B5zqHdk
SEEEEEE YAAAAAA!!............In my WAKE!!.............100N>>
Originally posted by DiGia54DMark...Call Gary Pond. That class you cant just use anything. Save yourself the trouble
A carefull search of the "Resources" tab and it is on page-5.
http://www.apba.org/resources?title=...tid=All&=Apply
1. Only genuine OMC service parts for this model (1986 or later) will be considered as legal replacement parts. This includes gear case bolts, connecting rod bolts, throttle plate screws, reed stop screws and cylinder head gasket. Other than listed above, any make or type of bolt, nut, screw, washer, or gasket may be used, provided it is equivalent to the original. Steering bar bracket bolts shall be grade 8 heat-treated and drilled for safety wire to match the OEM bolt. Steering bar bolts shall be grade 5 heat treated and fitted with elastic stop nuts and the steering bar swivel bolts are to be cross drilled and fitted with cotter pins to match the OEM configuration. All steering bar bracket and steering bar bolts shall have their heat treat markings clearly visible.
Apologies for the confusion.....(Guess I better pull the Sierra pumps from my A-motors).....
Since BRP bought OMC, Their packaged 15hp parts are "genuine" parts?..... Or is inspected by a stamped/cast part number on the pump? ( I have one motor with one....not sure if it is the#391667 or the #388685 improved "alcohol resistant" one.....)
So if it's a cold day in Haties and I beat Matt's pickles at the Nationals with my BRP pump'd motor??...........
(Don't have Gary's number.......)Last edited by STEVE FRENCH; 07-07-2013, 05:53 AM.100N STEVE FRENCH > Nobody can hang with my STUFF!! >> http://www.youtube.com/watch?v=tna3B5zqHdk
