parts needed
  • parts needed
    greetings to all
    i am needing good new or used 1 , 3 ring mercury 15 over (44 ci )Piston , 1 or 2 if you have them
    also need 1 for starters or 2 if you got em + 30 over 40 hp (39.9ci) merc 3 ring piston .
    need part number and or part , mercury large wrist pin piston spacers used to hold wrist pin bearings in place on the large wrist pin pistons 1 (8 pcs) set will do unless you want t part with 2 sets
    Pm me or email me at rrandal2003@yahoo.com
    Randy
    44 Spacers / Washers
    Randy, the part # is 12-47275, Mercury calls it 'Washer-needle locating'
    I have lots of new ones... $1 each + mailing
    Jerry.
    Also new standard bore two ring Keystone ring Mercury Pistons, $400 + mailing for a nicely matched set.
    New Standard bore Keystone rings, $100 + mailing.
    Various other new and used 44 parts... what do you need?
    Drop me a note at tridentracing@new.rr.com
    Jerry
