Bass Lower unit replacement gears.
  • Bass Lower unit replacement gears.
    Just checking to see if anyone is interested in new 1-1 gears for the bass lower units.
    We may produce some if enough interested racers want a different choice. Let me know your thoughts on it.. U can send private message, if what, also.. We just know that our FEs. are tearing them up.
      Are you using the thin driveshaft?
        I'm surprised to hear that you guys are tearing up that many gears. Andy is easily getting 2+ years out of his Bass gears under his FE and you know his equipment is powerful as it is always a front runner.
        Sattler Racing R-15
        350cc Pro Alcohol Hydro
        TEAM VRP
        The Original "Lunatic Fringe"
        Spokane Appraiser
          is the Bass factory not selling any more replacement gears?
          mike ross
            heard today that bass has about 200 sets just needs to get them heat treated
              Causes for gear failures
              If you are having pre-mature gear failures there may be several causes you should consider before expending a large sum of money trying to design and manufacture your own gears. A short stiff down shaft will transmit all the engine shock loading directly to the gears. That is why we recommend a turned down drive shaft as long as possible. The shorter the reduced diameter shaft, the quicker the gears will fail. Change the gear lube every race if not every heat. Use a lube that does not foam. Ask what the other FE drivers are using for lube. If your engine is detonating or excessively vibrating that too will damage the lower unit gears. Attached is our recommended drive shaft information.
              Have Better Luck,
              Neil Bass
                Are these gears cast or machined from bar-stock?
                How much for a set? (Ball-park est)
                How much would you charge to install a set, providing my seals and bearings are okay?
                What gear lube will you be recommending that I use?
                Can I get a 1 under set? (16 / 17)
                I've got a couple units with a lot of time on them, and they're both 1:1 at the moment.
                  Only 1-1 gears for now..
                  We could do other gears but what a huge cost for just a couple of people. 1-1 work in D stock, D mod and FE. And yea most likely we would have 2 do our own shafts.. We would redesign the splines on both.. working on price.. just depends on how many people interested.. Looking 4 at least 15 sets sold for a good break even price . Hoping 2 get Sets in the $350 range but cheaper is better yea!
                    1-1- bass gears
                    I AM ON MY 6TH YEAR WITH Same SET OF 1-1 GEARS IN MY bASS UNIT. I TAKE IT APPART EVERY 6 HEATS AND TURN THE GEAR 1 TOOTH, USE GOOD OIL AND TURN YOUR DRIVE SHAFT DOWN FROM ORIGINAL SIZE TO 1/2 INCH IN THE CENTER SECTION TO REDUCE LOAD.
                    I HAVE NEVER LOST A SET OF BASS GEARS under My FEH or the 1100 6 cly. engines.
                      Bass Gears
                      I run a set of one to one gears for my Tohatsu D stock...just checked them, and they look brand new. I am running Mercury lower unit lube...should I think about changing to a synthetic blend? I think I have around 80 heats on them. Any help would be appreciated, David
                        I would say if it ain't broke don't mess with it
                          Though i am looking for Lower Unit Replacement of my Yamaha engine and after a long search i got one. I think its better to replace as previous one got damaged.
                            I ran my Bass 1-1 gears for 7 years still have the original set in my units, Good oil, and tapering down the drive shaft is the Key. Also take them apart and turn the gear 1 tooth very 6 races.
                            Also make sure your alignment is good.
                            R777
                              Please read what you just printed, 80 heats and they look brand new?? Don't change a thing except your mind about running a different lube!
