looking for pro engine
  • looking for pro engine
    looking for 2 cylinder 350cc pro engine.engine must set up from 97 octane gas.bolt on powerhead or complete engine.best regard Mr Lo.
    Good luck
    All the fast Pro Motor's are set up to run Alcohol. I know where there is a 350cc VRP 2-Cylinder for sale, but it's ready for Alcohol. You could easily make this motor run on gas, but I'm not really sure why you would want to. Let me know if you are interested.
    Sattler Racing R-15
    350cc Pro Alcohol Hydro
    TEAM VRP
    The Original "Lunatic Fringe"
    Spokane Appraiser
      Mikuni Carburetors for Gasoline
      I can set you up Mikuni Flatslide Caruretors, set up for Gasoline. I'd recommend 2 Mikuni 38mm (or up to 41mm) Flatslide Carburetors, for a 2 cyl 350cc.
      Jim McKean
      E-Mail:"captainjimmckean@yahoo.com"
        looking 2 cylinder 350cc pro engine set up for gas
        the reason why i would like to convert it to gas is because there is no methanol fuel available in the country i live.the only alcohol fuel i ever seen is the nitro fuel using on the hobby nitro rc.and the highest gas i can get from the local gas station is 97 octane gas.best regard Mr Lo.
          350 cc gas burner
          If you buy a 350 cc motor set up for methanol, you will need to open up the cylinder heads a little. The compression is too high on a alky burner to run gas without modifications.
          Rex Hall
            What country do you live in? I know many people all over world that race and I'm sure they can help with methonal. I can give to you contact information for this. I also sell new Motors From VRP and Konny but Konny makes only 500/700 motors at this time. Steve
