Call me if you need a Yamato-tuned C-mod pipe, pipe bracket, passage tube blocks, and custom manifold. I have those parts to sell that worked well on a Y102 motor that I just sold. I don't know if the set will work on a Y302 (port dimensions might be a little different, so the flat header plate may need to be modified a little, and you might have to make your own passage tubes.)
Need pipe and hardware. Thanks Steve 22-R QUINAULTRACING
boy Steve, you need to be more specific on what motor!! I "assume" a Yamato 302? Get you butt in gear and get the motor together (don't procrastinate!!!), as there are a few more being put together for 09 (including mine)...........
