The brass/bronze? two blade prop is 7x13 but has 1/14 stamped on it and has obvious cupping it also has a capital B stamped in the side. 9/16 prop shaft with 3/16 shear pin.
$75
The 25SS prop is stainless in Quite nice condition, only a couple small dings and I mean small. It has 25SSMG and 974 375 with RE vertically between 974 375. In comparison this prop is almost the same as the bronze one in pitch and diameter, I cannot differ the pitch between the two by eye. Also this prop doesnt have that 'notch' on the bottom like the bronze one. 9/16 prop shaft with 3/16 shear pin.
$100
I was unable to get pics tonight of the 25SS prop because windows tells me my camera is malfunctioning, I think the USB cable is bad as one end was bent some. I will get pics of the 25ss prop up tomorrow.
$75
$100
