Parts
Quantity Part # Item New *Price (Each)* Total
3 5006702 .030 Piston / Ring Assembly* *$******************** 105.00 $315.00
Quantity Part # Item Comes as Set *Price (Each)*
2 38834 Big End Rod Roller Bearing - New* *$********************** 10.00 $20.00
15 38834 Big End Rod Roller Bearing - Used *$************************ 8.00 $120.00
Quantity Part # Item Used *Price (Set)*
6 SST60 SST-60 Boyesen Blue Reed - set *$********************** 50.00 $300.00
Quantity Part # Item Used *Price (Each)*
6 396521 Float Valve & Seat Assy SST-60 Carb *$********************** 10.00 $60.00
9 394462 Connecting Rods - Used *$********************** 40.00 $360.00
1 395820 Crank Case Bottom End Cap / with Seal *$********************** 10.00 $10.00
4 377139 Crank Bearing Assy - Bottom *$********************** 20.00 $80.00
8 378252 Retainer (Needle Bearing) - Crankshaft *$********************** 15.00 $120.00
Quantity Part # Item Used *Price (Each)* **
6 390900 Crank Roller Bearing - Top *$********************** 25.00 $125.00
Quantity Part # Item New *Price (Each)* **
1 328788 Crankshaft (Stroke T=36/M=39/B=32) *$******************** 800.00 $800.00
1 328788 Crankshaft (Stroke T=42/M=46/B=39) - Fully Dressed all Bearings *$******************** 500.00 $500.00
1 328788 Crankshaft (Stroke T=43/M=40/B=45) *$******************** 300.00 $300.00
6 322188 Wrist Pins *$************** 10.00 $60.00
9 322188 Wrist Pin** *$**************** 5.00 $45.00
3 395627 Retainer & Needle Bearing Kit *$************** 10.00 $30.00
3 395627 Retainer & Needle Bearing Kit *$************** 25.00 $75.00
2 Flywheel Nut *$**************** 5.00 $10.00
2 New 70 HP Cylinder Head - Needs Blueprinting *$************** 80.00 $160.00
20 308186 Rod End Cap Bolts *$**************** 0.50 $10.00
Quantity Part # Item *Price (Each)* **
1 SST-60 Custom Torque Plate (Boring/honing precision) *$************ 250.00 $250.00
1 583222 Flywheel *$************ 125.00 $125.00
1 343863 New Gasket - Exhaust *$**************** 3.00 $3.00
7 329836 Head Gasket *$************** 18.00 $126.00
2 329830 Gasket - Thermostat *$**************** 0.25 $0.50
1 391735 Starter *$************** 90.00 $90.00
1 583378 Trigger / Timing Base *$************ 120.00 $120.00
1 586180 Starter Solenoid *$************** 20.00 $20.00
3 582508 Coil - Used *$************** 12.00 $36.00
3 582508 Coil - New *$************** 20.00 $60.00
4 582115 Power Pack *$************** 75.00 $300.00
1 Rectifier - Used *$************** 10.00 $10.00
1 Rectifier - New *$************** 20.00 $20.00
1 - Carb Carburetors Rebuild Kit - New Float Assy, Needle and Seat, Bowl Gasket *$************ 50.00 $50.00
1 511807/333448 Primer Cover & Gasket *$************** 20.00 $20.00
1 Bracket Electrical *$************** 20.00 $20.00
1 Race Communication Water Communication Kit, 3 Radios, 3 Chargers, in-boat water proof box, shark fin, driver push to talk button, all wiring, crew chief head set, case. *$************** 1150.00 $1,150.00
3 3-Blade Impeller* *$************** 10.00 $30.00
2 5-Blade Impeller - Used *$************** 10.00 $20.00
2 5-Blade Impeller - New *$************** 15.00 $30.00
1 386659 SST-60 prop shaft *$************ 125.00 $125.00
1 320127 Gear Case Shift Rod *$**************50.00 $50.00
1 Test Wheel SST-60 *$************ 350.00 $350.00
1 391049 Water Pump Housing *$*********** 20.00 $20.00
3 319275 Plate Impeller Housing *$*********** 12.00 $36.00
5 Gearcase drive shaft 0-Rings *$*********** 1.00 $5.00
1 Blow out Hub - Long *$************ 125.00 $125.00
1 Blow out Hub - Medium *$************** 75.00 $75.00
1 Blow out Hub - Medium *$************** 60.00 $60.00
1 Blow out Hub - Short *$************** 50.00 $50.00
12.75" x 22" Titus Short Course $600 $600.00
12.625" x 22" PP4 Short Course ( 32 - 35 seconds) $600 One of my best props $600.00
Titus / Croxton Short Course $800 $800.00
12.75" x 23" PP1 Medium Course $600 $600.00
12.625" x 23" RA1 Medium - Short Course $600 $600.00
12.625" x 22" PP5-Mazco Short Course (28 - 31 seconds) $600 $600.00
12.75" x 23" PP1-BK Medium - Short Course $600, $600.00
1 Holley Fuel Pump *$************** 30.00 $30.00
2 Mercury Power Trim Pump Oildyne *$************** 300.00 $600.00
For any questions please contact Blair Kants @ kantsracingteam@hotmail.com
1 Fuel Pressure Regulator & Gauge *$************** 30.00 $30.00
1 1" stainless steering shaft w/3.5" hub and quick-release assembly *$************** 125.00 $125.00
1 SST-60 Steering Bar Set *$************** 90.00 $90.00
1 SST-60 Mid Section 750 $750.00
1 Steering Cable New (40 Ft) 1/8" stainless aircraft *$************** 50.00 $50.00
